11-23-2011 09:43 AM - edited 03-16-2019 08:12 AM
I'm using Unified Communication Manager (Call Manager) 7.1.5, and supporting 3000 IP Phones, I was successfully able to customize a background image for IP Phones model 9971, 7975, 7970 and 7945.
The issue: users need to select the customized image, is there a way were I can force the customized image to be the default image and display it on all the IP Phones? without using any third party application, I want to do it directly from the call manager.
Appreciate it.
Zaid,
11-23-2011 10:01 AM
Zaid,
I did a write up on this a while back that may still be relevant. In the write up I talk about Cisco's Phone Designer, a method to programmitically do this, and a reference to a 3rd party app that claims to solve the problem you are talking about.
Unfortunately, you can't push this directly from CUCM.
The article link:
http://netcraftsmen.net/resources/blogs/pushbackgroundtoipphone.html
HTH.
Bill
please rate helpful posts
11-23-2011 10:20 AM
I've written a wee application that can do this (admittedly some inspiration from Bill there). Should have it online pretty soon hopefully... watch this space.
Aaron
01-31-2012 07:12 PM
Aaron - Any progress on getting that online?
-Luke
01-31-2012 08:10 PM
just use voip integration software for the ip phone background
simple and dose the job
http://www.voipintegration.com/software.html
hope this help
02-01-2012 09:40 AM
Hi Luke
Yep - it's at www.ipcommute.co.uk
As suggested, www.voipintegration.com have a similar app and UnifiedFX www.unifiedfx.com seems to have the functionality as well.
Principal Engineer at Logicalis UK
Please rate helpful posts...
02-02-2012 03:10 AM
Just remove all backgrounds from the tftp directory, and only leave/ add the background you want, this will default all phones to that one background, without the need for individual customization
