FORCE BACKGROUND IMAGE
I'm using Unified Communication Manager (Call Manager) 7.1.5, and supporting 3000 IP Phones, I was successfully able to customize a background image for IP Phones model 9971, 7975, 7970 and 7945.
The issue: users need to select the customized image, is there a way were I can force the customized image to be the default image and display it on all the IP Phones? without using any third party application, I want to do it directly from the call manager.
Appreciate it.
Zaid,
6 Replies 6
William Bell
Zaid,
I did a write up on this a while back that may still be relevant. In the write up I talk about Cisco's Phone Designer, a method to programmitically do this, and a reference to a 3rd party app that claims to solve the problem you are talking about.
Unfortunately, you can't push this directly from CUCM.
The article link:
http://netcraftsmen.net/resources/blogs/pushbackgroundtoipphone.html
HTH.
Bill
please rate helpful posts
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
I've written a wee application that can do this (admittedly some inspiration from Bill there). Should have it online pretty soon hopefully... watch this space.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron - Any progress on getting that online?
-Luke
just use voip integration software for the ip phone background
simple and dose the job
http://www.voipintegration.com/software.html
hope this help
Hi Luke
Yep - it's at www.ipcommute.co.uk
As suggested, www.voipintegration.com have a similar app and UnifiedFX www.unifiedfx.com seems to have the functionality as well.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Dennis Mink
Just remove all backgrounds from the tftp directory, and only leave/ add the background you want, this will default all phones to that one background, without the need for individual customization
Please remember to rate useful posts, by clicking on the stars below.
