Community Member
Force IP phone login
Running CUCM 7.02
7911, 7942 handsets
Wanted to secure some phones out of hours, was looking at doing some Time of Day Routing but wanted to users to be able to login to override the block.
Does anyone know a way to force user login on phones before CSS becomes active.
1 REPLY
Re: Force IP phone login
You would need to look into 3rd party solutions to lock the phones (search NetPro and you'll find plenty of posts on the subject)
Or use EM
java
if this helps, please rate
java
www.cisco.com/go/pdi
115
