Force refresh background
olivier.bedard
Is it possible to force a refresh of the background image on 7945 IP Phones ?
Reseting the phone does not force it to reload the picture.
Thanks.
Jaime Valencia
Do it on the phone or via phone designer, the phone does not send the TFTP request unless you instruct him to do so.
java
if this helps, please rate
java
Thanks for the reply.
I'd like to avoid having to refresh the background manually on 200 phones each monday mornning :)
Also, it seems like Phone Designer does not support CallManager Express.
Any other tip ?
Are there any HTTP calls available on the phone's web interface that could be used ?
Thanks !
If you want to do it on 200 phones on a weekly basis, just replace the background file on the TFTP server over the weekend then reset all the phone early Monday morning.
As stated in the original post, reseting the phone does not force it to reload the picture. Even if it's a new picture on the server.
