Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Forced Authorization Codes
I am presently on Call Manager 4.1 with all my Gateways running MGCP. I would like to switch to H.323 for the caller ID and T.37 protocols. However, as the Cisco Documentation states, FAC is not supported on an H.323 gateway because the gateway does not support the generation of tones. So...if I tell my users to type in the code 1 to 2 seconds after they dial the number (not hearing any tone of course), will it work?
Thanks for any assistance,
Andrew
Re: Forced Authorization Codes
Andrew,
Only H323 analog gateways dont support this feature. Are you using FXO or PRI ?
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_1/sys_ad/4_1_3/ccmfeat/fsfaccmc.htm
Both, but I am specifically speaking about the FXO ports.
171
