Forced logoff for EM users after fixed time
Is it possible to configure forced logged off for extension mobility users after some time say 4 hours. What parameter we need to change in eneterprise/service parameter.
Brajesh.
1 ACCEPTED SOLUTION
Re: Forced logoff for EM users after fixed time
Yes, configure this EM service parameters.
This is from 8.X but they look quite similar in previous versions, only you don't get the inter or intra as this only exists in 8.X and above.
Enforce Intra-cluster Maximum Login Time  -> TRUE
Intra-cluster Maximum Login Time Required Field -> TIME
Inter-cluster Maximum Login Time Required Field
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
205
