forcing an ext. to use a specific outbound FXO port
I want to force a particular extension to use a specific FXO for billing.
I can't seem to find the documentation on this for CCME.
Andy
1 ACCEPTED SOLUTION
Re: forcing an ext. to use a specific outbound FXO port
ok this can be done trhoguh COR list
lets say the port is 0/0/1
do the following
dial-peer cor custom
name fxo
name all
dial-peer cor list restrected
member fxo
dial-peer cor list not-restrected
member fxo
member all
dial-peer cor list fxo-only
member fxo
dial-peer cor list all-ports
member all
creat dialpeer going through that fxo
for example
dial-peer voice 9 pots
destination-pattren .T
Cor outgoing fxo-only
port 0/0/1
now lets say u have other ports u want other employees to use it
Cor outgoing all-ports
port 0/0/2
now apply the cor list in the incoming directionto the extention line
for example:
Ephone-dn 1
cor incoming restrected
Ephone-dn 2
cor incoming not-restrected
based on the config above the DN 1 will have access only to port 0/0/1 while DN 2 will have access to both !
if u want only DN have access to only that port just remove the member fxo from not-restrected
so the DN 1 will have access to port 0/0/1 and DN 2 will have access to port 0/0/2
good luck
if helpful Rate
1 REPLY
do the following
name fxo
name all
member fxo
member fxo
member all
member fxo
member all
for example
port 0/0/1
port 0/0/2
for example:
Ephone-dn 1
Ephone-dn 2
good luck
if helpful Rate
434
