formula in crs (ivr)
How to write next formula is easier:
if (p_value == -1 && type == "01" && status == "01" || p_value == -1 && type == "01" && status == "04" || p_value == -1 && type == "01" && status == "05" || p_value == -1 && type == "01" && status == "06" || p_value == -1 && type == "02" && status == "01" ..... )
Data:
type = 01, type = 02, type = 05, type = 06
status = 01, status = 04, status = 05, status = 06
1 ACCEPTED SOLUTION
Super Bronze
Re: formula in crs (ivr)
Not sure if this is 'easier', but it may be shorter. This will *probably* require a premium license, but I can't realy test that here.
Try this:
1) Add a boolean variable called 'testresult' or whatever
2) Add a 'set' step, and set testresult to this:
String[] acceptStatus = new String[] {"01","04","05","06"};  // Set up list of types that should return true
String[] acceptTest = new String[] {"01","02","05","06"}; // Set up list of status that should return true
if (java.util.Arrays.asList(acceptStatus).contains(status)
&& java.util.Arrays.asList(acceptTest).contains(type)
&& p_value  == -1){
  return true;
} else{
  return false;
3) You can then use 'testresult' as a test for the If step an do what you will under that.
Aaron
Please rate helpful posts....
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
1 REPLY
Super Bronze
Try this:
&& p_value  == -1){
  return true;
} else{
  return false;
Aaron
279
