paa
Forwad call back to originator if transfer to target phone fail (noan)
Hi!
I have a problem. Phone-A transfer a call to Phone-B, Phone-B no answer. How can I configure CCM 6.0 to transfer call back to Phone-A if Phone-B no answer? In CCME this feature work - any noan call forward back to originator if nobody aswer on transfered phone.
Green
Re: Forwad call back to originator if transfer to target phone f
We have Callback feature, which will notify when Phone B is active again.
You may be doing a Blind transfer. You need to do consult one as of now we dont have that feature in CCM :(
You can configure CFNA internal to a main extension not sure if that helps
Cheers
paa
Thanks! I open TAC, hope they find that feature =)
Have you found the decision?
CUCM doesn't have this feature.
Transfer reversal is only available using the CUxAC products.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
284
