Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Forward a Hunt group to external number
Is there a way to forward a hunt group to an external number?
I am looking at setting up a hunt group for a group of phones, but need to be able to forward it after hours to a cell phone.
Is this possible, for a non admin user to do?
Doug
1 REPLY
Re: Forward a Hunt group to external number
Not really the config for the FW needs to be done by someone who can access CCMAdmin, why don't you configure TOD and then use it to FW the call to the mobile afterhours??
java
if this helps, please rate
java
www.cisco.com/go/pdi
239
