Forward all incoming calls from specific country to specific extension
Using CME 4.1, IOS 12.4(15)T9. Cisco 3825.
How do I route all incoming calls from a certain country to a certain single extension number? Is it even possible?
Can I use the answer-address command together with a destination-pattern command under a inbound dial-peer to accomplish this? I've read the documentation about answer-address, but I don't know if I understand it.
Thanks in advance.
Grant
paolo bevilacqua
Yes, you need to use answer-address on a DP on which a translation-profile incoming that sets the desired destination.
5 Replies 5
paolo bevilacqua
Thank you.
Something like this? +31 is the country code for the Netherlands.
translation-rule 1
rule 1 /316xxxxxxxx/ /765xxxxxx/
translation-profile TEST
translate calling 1
dial-peer voice 1000
answer-address 31T
translation-profile incoming TEST
Yes, but you need to translate the called number, not calling.
I will like to add my two cents to Paulo's comment:
If any dial-peer on the incoming call leg is configured with "incoming called-number ." answer address based inbound dial-peer matchiing will fail since incoming called-number scores above answer-address. So remember that you remove any incoming called-number command on inbouund call leg.
Alright.
Thank you both.
I'll try to get this working.
~Grant
