forward all not working
hi all!
When i activate Forward ALL on Cisco Phone to number that begins 8... forward works fine . IF i use 08.. (08 calls going through another department )  i listen silence.
Calls through 08 without Forward ALL working fine
I  write rules  to Forward all internal calls to my mobile phone but its not helps me .
voice translation-rule 200
rule 1 /\(^68..\)/ /08_my_mobile_phone_number\1/   after that rule try rule 1 /^68../ /08_my_mobile_phone_number/
voice translation-profile 1
translate calling 200
ephone-dn 1
translation-profile outgoing 1
sh call history voice brief shows:
879  : 1980520 75536864ms.5231 (10:50:53.597 Russia Wed Jul 30 2014) +-1 +980 pid:40003 Answer 6802
 dur 00:00:00 tx:0/0 rx:0/0 10  (normal call clearing (16)) dscp:0 media:0 audio tos:0x0 video tos:0x0
 IP IP_PHONE:20686 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded No
  media inactive detected:n media contrl rcvd:n/a timestamp:n/a
  long duration call detected:n long dur callduration :n/a timestamp:n/a
 LostPacketRate:0.00 OutOfOrderRate:0.00
87F  : 1980523 75537864ms.5232 (10:50:54.597 Russia Wed Jul 30 2014) +-1 +50 pid:1002 Originate 08_my_mobile_phone_number
 dur 00:00:00 tx:0/0 rx:0/0 1   (unassigned number (1)) dscp:0 media:0 audio tos:0xB8 video tos:0x0
 IP 0.0.0.0:0 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded No
Everyone's tags (1)
1 ACCEPTED SOLUTION
When sending the Invite out
When sending the Invite out to the other department, you're getting a 404 Not Found from them.
First attempt:
018708: Jul 30 18:11:11.245: //1994314/315DCB75B7F5/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:mobile_phone@172.31.5.2:5060 SIP/2.0
Via: SIP/2.0/UDP CISCO_IP:5060;branch=z9hG4bK3C523CC17
Remote-Party-ID: "NAME" <sip:6820@CISCO_IP>;party=calling;screen=yes;privacy=off
To: <sip:mobile_phone@172.31.5.2>
Date: Wed, 30 Jul 2014 14:11:11 GMT
Call-ID: 31603CAD-172A11E4-B7FBEC04-71085274@CISCO_IP
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0828230517-0388633060-3086347268-1896370804
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1406729471
Contact: <sip:6820@CISCO_IP:5060>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Diversion: <sip:6811@CISCO_IP>;reason=unconditional;counter=1
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 265
v=0
o=CiscoSystemsSIP-GW-UserAgent 4795 2908 IN IP4 CISCO_IP
s=SIP Call
c=IN IP4 CISCO_IP
t=0 0
m=audio 25022 RTP/AVP 0 101 19
c=IN IP4 CISCO_IP
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
It sends the Invite again:
018711: Jul 30 18:11:11.741: //1994314/315DCB75B7F5/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 265
v=0
s=SIP Call
c=IN IP4 CISCO_IP
t=0 0
c=IN IP4 CISCO_IP
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
CME receives 100 Trying:
018712: Jul 30 18:11:11.761: //1994314/315DCB75B7F5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Wed, 30 Jul 2014 14:11:21 GMT
Allow-Events: presence
Content-Length: 0
CSeq: 101 INVITE
CME sends 404 Not Found:
018713: Jul 30 18:11:11.785: //1994314/315DCB75B7F5/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
Reason: Q.850;cause=1
Content-Length: 0
To: <sip:mobile_phone@172.31.5.2>;tag=ad803d66-05af-4540-8ebe-481e90667f53-20224504
CSeq: 101 INVITE
It may be because of the Diversion header in the Invite that the other side doesn't like or it may be because the number format is not correct.  You may want to compare to an Invite from a direct call that does work.
You could try removing the diversion header:
voice class sip-profiles 100
  request INVITE sip-header Diversion remove
voice service voip
   sip
     sip-profiles 100
VIP Super Bronze
Can you share your sh run
Can you share your sh run here..Also can you attach the output of the following debug while testing the cfwd issue...
debug voip ccapi inout
debug isdn q931 (if you are using ISDN)
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Thanks for your answer.I
I execute
voip ccapi inout debugging is on
After that i try testing call but no have any messages.
Second command not worked
debug isdn q931
% Invalid input detected at '^' marker.
i put running conf but wait few minutes pls
output of sh run  in
output of sh run  in attachment
VIP Super Bronze
Can you do anothere test and
Can you do anothere test and send the ff:
debug ccsip messages
i send term on and debug
i send term on and debug ccsip messages
6820 - from called
6811 - phone where Call Forwarding Enable to mobile_phone
Sent:
INVITE sip:mobile_phone@IP_of_other_department:5060 SIP/2.0
Via: SIP/2.0/UDP CISCO_IP:5060;branch=z9hG4bK3C47391A8B
To: <sip:CISCO_IP@IP_of_other_department>
Date: Wed, 30 Jul 2014 13:25:38 GMT
Call-ID: D1FD10FF-172311E4-B7E3EC04-71085274@CISCO_IP
Min-SE:  1800
Cisco-Guid: 3509902782-0388174308-3084643332-1896370804
CSeq: 101 INVITE
Timestamp: 1406726738
Expires: 180
Max-Forwards: 69
Content-Length: 265
v=0
o=CiscoSystemsSIP-GW-UserAgent 7250 5685 IN IP4 CISCO_IP
s=SIP Call
c=IN IP4 CISCO_IP
t=0 0
m=audio 25016 RTP/AVP 0 101 19
c=IN IP4 CISCO_IP
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Sent:
INVITE sip:mobile_phone@IP_of_other_department SIP/2.0
To: <sip:mobile_phone@IP_of_other_department>
Date: Wed, 30 Jul 2014 13:25:42 GMT
Call-ID: D1FD10FF-172311E4-B7E3EC04-71085274@172.23.1.2
Min-SE:  1800
CSeq: 101 INVITE
Timestamp: 1406726742
Expires: 180
Max-Forwards: 69
Content-Length: 265
v=0
s=SIP Call
c=IN IP4 CISCO_IP
t=0 0
c=IN IP4 CISCO_IP
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Jul 30 13:25:42.675: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CANCEL sip:mobile_phone@CISCO_IP:5060 SIP/2.0
Via: SIP/2.0/UDP PHONE_IP:5060;branch=z9hG4bK3d64955a
From: "NAME" <sip:6820@CISCO_IP>;tag=7c95f322ab0b0fd64d5cf396-06f405a6
To: <sip:6@CISCO_IP> ###### only 6
Call-ID: 7c95f322-ab0b00a1-5abe5a7f-7ef1f373@172.23.1.40
Max-Forwards: 70
Date: Wed, 30 Jul 2014 13:25:41 GMT
CSeq: 102 CANCEL
User-Agent: Cisco-CP8961/9.3.2
Content-Length: 0
Jul 30 13:25:42.675: //1992896/D134DDBEB7DB/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x3DC80904, Call Id=1992896
   Call Entry(Responsed=FALSE, Cause Value=16, Retry Count=0)
Jul 30 13:25:42.675: //1992898/D134DDBEB7DB/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=FALSE, Cause Value=16)
Jul 30 13:25:42.675: //1992896/D134DDBEB7DB/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jul 30 13:25:42.679: //1992896/D134DDBEB7DB/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Via: SIP/2.0/UDP 172.23.1.40:5060;branch=z9hG4bK3d64955a
Call-ID: 7c95f322-ab0b00a1-5abe5a7f-7ef1f373@PHONE_IP
CSeq: 102 CANCEL
Content-Length: 0
Sent:
SIP/2.0 487 Request Cancelled
To: <sip:6@CISCO_IP>;tag=5EA1170-1428
CSeq: 102 INVITE
Server: Cisco-SIPGateway/IOS-15.3.3.M
Reason: Q.850;cause=16
Content-Length: 0
Jul 30 13:25:42.759: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:mobile_phone@CISCO_IP:5060 SIP/2.0
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
Jul 30 13:25:42.759: //1992896/D134DDBEB7DB/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3DC80904, Tag=0x0, Call Id=1992896,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Jul 30 13:25:42.763: //1992896/D134DDBEB7DB/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
Jul 30 13:25:42.763: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jul 30 13:25:42.763: :cc_free_feature_vsa freeing 21013B50
Jul 30 13:25:42.763:  vsacount in free is 3
Jul 30 13:25:42.763:  vsacount in free is 2
Jul 30 13:25:42.763: //1992896/D134DDBEB7DB/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x3CF18AD8
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 6820
Called Number            : mobile_phone
Source IP Address (Sig  ): CISCO_IP
Destn SIP Req Addr:Port  : PHONE_IP:5060
Destn SIP Resp Addr:Port : PHONE_IP:49153
Destination Name         : PHONE_IP
Jul 30 13:25:42.763: //1992896/D134DDBEB7DB/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): CISCO_IP
Source IP Port    (Media): 25012
Destn  IP Address (Media): PHONE_IP
Destn  IP Port    (Media): 27526
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 487
VIP Super Bronze
These logs doesnt look
These logs doesnt look complete..Please use the instruction below to prperly collect logs.
service sequence-numbers
service timestamps debug datetime localtime msec
logging buffered 10000000 debug
no logging console
no logging monitor
default logging rate-limit
default logging queue-limit
Then..
<Enable debugs, then test again.>
<Enable session capture to txt file in terminal program.> (such as Putty)
then do the ff:
terminal length 0
show logging
OK i try
OK i try
 i send all this commands in
 i send all this commands in config mode and aftre that send
term on
and testing calls i dont have any messages on router console
VIP Super Bronze
yes you wont because its
yes you wont because its logged to router buffer..Follow the instruction.you need putty to collect the logs
ok
ok
trace in attachment
trace in attachment
mobile_phone  - phone where call forwarding
6811 - phone where Call forward ENable
6820 - phone from Called to 6811
VIP Super Bronze
There is no sip calls in this
There is no sip calls in this trace. It just contains SIP REGISTER messages.
First attempt:
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 265
v=0
s=SIP Call
c=IN IP4 CISCO_IP
t=0 0
c=IN IP4 CISCO_IP
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Sent:
Min-SE:  1800
CSeq: 101 INVITE
Expires: 180
Max-Forwards: 69
Content-Length: 265
v=0
s=SIP Call
c=IN IP4 CISCO_IP
t=0 0
c=IN IP4 CISCO_IP
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
Received:
SIP/2.0 100 Trying
Content-Length: 0
CSeq: 101 INVITE
Received:
Content-Length: 0
CSeq: 101 INVITE
voice service voip
   sip
     sip-profiles 100
Thanks for your help. I try
Thanks for your help, Brian. I try remove diversion header and will notify you
Thanks for your help Brian
Thanks for your help Brian and Ayodeji
Brian you solution helps me. Thank you very much!
I can Forward ALL now to  08 ext numbers without rules
You said you can or can't
You said you can or can't forward all now?
My mistake . I can forward
My mistake . I can forward all
174
