Community Member
forward all programmable??
Hi all,
It's possible to configure a button with a forward all + Directory Number??
thanks
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
Re: forward all programmable??
Sorry, but this is not doable. You can configure a speed dial to the DN, and then press CallFwdAll and the speeddial button.
HTH,
Chris
if you got CME this can be done using an easy code that does all the work ie *86 to CFA to your mobile, but CUCM does not have the capability
java
if this helps, please rate
java
www.cisco.com/go/pdi
HTH,
Chris
java
java
162
