Community Member
Forward call from CME via SIP trunk
Hello everyone
Is it possible to forward a call from a specific number coming from ISP to a specific number via SIP trunk directly from CME.
I know I can configure call forward on the phone, but I need to receive a number from ISP and forward it directly from CME via SIP trunk
Thank you
Hi.well... this is what a
Hi.
well... this is what a cube does.
ISP ---> CUBE ----> CUCM via Sip Trunk --> ip phone
If you can post your actual config, we can suggest you a right direction.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Community Member
Thank you,I have not got CME
Thank you,
I have not got CME yet, just trying to understand, if it is going to work
So what the CUBE is? Is it a feature of CME?
Hi.Yes with an appropriate
Hi.
Yes with an appropriate configuration it will work.
CUBE or Cisco Unified Border Element basically is a session border controller in other words what in the past was called IP to IP gateway with some more powerful features.
You can start from here
http://www.cisco.com/c/en/us/products/unified-communications/unified-border-element/index.html
Carlo
51
