Forward calls from voicemail menu
ajmadriaga
Is it possible to enable call forwarding from your voicemail menu?
Scenario:  Call voicemail > enter ext./password > menu "5" forward calls > enter number to forward calls to.
Thanks.
Jaime Valencia
If you mean to change the call forward settings from CUCM via Unity/CUC, no, that's not possible.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
