Forward Hunt No answer/Busy > Voicemail Pilot > Call Handler
I am trying to forward a hunt pillot when No answer/Busy to voicemail pilot where it would hit a Call handler with the same extn as the hunt pilot.
But the greeting played is standard greeting when it hits the Call Handler. Why is it not hitting the busy greeting in the call handler for Forward Hunt busy?
I am using CUC 8.6
Your help is much appreciated.
Libin
Think is not the right way
Create a virtual number into cti route point and tick the forward ALL options to voicemail
Example 3000 .point your hunt pilot to this number
Then go to CUC to the system cll handler and create there one call handler with extension 3000.Then go to the tranfer rules anf choose standar/Transfer Action/Greeetings
Go to Greeetings and enable the busy .Then there  add  any prompt you want or any other choise
Please rate all useful posts
Chrysostomos
""The Most Successful People Are Those Who Are Good At Plan B""
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Is it possible to provide 2 greetings (one when No Answer and the other when Busy) with this configuration?
Libin
As far as i know no you cant.
But you can send the call into the call hanlder in case that is no answer or is busy with the same prompt that you will choose .In any case the result is the same,.The extensions into the hunt pilot are not able to answer the call so the result is the same if are  busy or if not answer
Chrysostomos
If that is the case, I can follow the method I mentioned initially which will hit the standard greeting which will play the same prompt for No Answer or Busy.
I was actually looking for a method which will play the standard greeting when No Answer and Busy greeting when busy.
Thanks and Regards,
Libin
you can use your hunt pilot to have something for the no answer and something else for the busy
But you have to configure your hunt pilot to accept only one call and the second call will not come into hunt pilot/extensions but to the destination call handler for example
Chrysostomos
Re: Forward Hunt No answer/Busy > Voicemail Pilot > Call Handler
use direct transfer to voicemail, on your hunt forward busy and hunt forward no answer settings
http://ciscoshizzle.blogspot.com.au/2012_09_01_archive.html
You can differentiate between a no answer and busy greeting, all you need to do is go to the user (in CUC) and enable the busy greeting and record it.
Please remember to rate useful posts, by clicking on the stars below.
Will different greetings be played for No answer and busy scenarios?
As per my knowledge, if you enable busy greetings, it overrides the standard greetings.
Libin
1377
