Community Member
Forward No Answer bypass IVR
Good afternoon,
My question is how to bypass the IVR. The situation is: if A rings to B, and B rings and it is not picking up, but forwarding on C. And if C does not answer, the call is forwarded to the Call Center, and vice versa A-> C-> B-> Call Center. The problem is that there is a Call Center IVR, but I need to patrol this IVR and got through to an operator.
1 REPLY
Re: Forward No Answer bypass IVR
Then you need to setup call forward on B or C (last device) to operator ext directly.
97
