Forward two different dial numbers at the same time to the same destination
Hello everybody,
I need to forward two different dial numbers in the same phone (Cisco 6921) to the same destination.
I'd change the phone if it'll be necessary.
Forward from the end user web is not a valid posibility. It is neccesary to do this forward from the phone.
Any idea, suggestion or testing scenario should be appreciated.
I use CUCM 8.5
Thanks in advance.
1 REPLY
you can mask the other number
you can mask the other number by using translation pattern
18
