Forwarding Call To Another Phone After X Rings
I have a 7940 phone where the end user wants the phone calls to that phone to be forwarded to another phone after 3 rings on the first phone. Is this possible, and if it is how do you go about configuring this situation in Call Manager. I have Call Manager 6.1 running.
1 REPLY
Re: Forwarding Call To Another Phone After X Rings
yes, it's possible
simply configure the CFNA and CFB to the other phone under the device config
java
if this helps, please rate
java
www.cisco.com/go/pdi
108
