Forwarding DTMF tones
I have a requirement for the following.
An incoming call to an efax DID(x1234) is forwarded to our fax server at x9876. What I need to do is have the fax server know the call was forwarded from x1234 so it will route the fax appropriately to the right person.
The GW is h3.23
CUCM 7.0.2
The Fax server is on a VG 224
Randall
Hall of Fame Super Gold
Re: Forwarding DTMF tones
Have you enabled clid ?
That is only way you can forward info about caller, not dtmf.
Hi Paolo,
It is enabled on each port of the vg224.
Randall
185
