Found the Serial Number
wilsonsant
Level 6
Level 6
My customer lost the label the serial number CallManager. Is possible found the serial number by software callmanager?
Thank You,
Wilson
Jaime Valencia
just a mouse scroll from your post:
CM 6.1 serial number
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&topicID=.ee6c829&fromOutline=&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.2cc10df5
If it's not linux appliance then there is no way other than going to the server itself.
You might also find the information on the purchase order if bought from Cisco.
BTW, you can also use the search feature on NetPro, someone might have asked the same thing before
javalenc
if this helps, please rate
java
Hi Javalenc,
I am sorry, but, my customer have the CallManager version 4.1.3.
Thank You,
Wilson
