Fractional PRI
On what protocol can fractional PRI be configured, H.323 or MGCP? Think it's H.323 but not sure.
5 ACCEPTED SOLUTIONS
VIP Super Bronze
Re: Fractional PRI
I have used fractional PRi on MGCP. People say its not supported, but I think it is. Because I have used it before. To be safe stay with H.323
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
VIP Super Bronze
Re: Fractional PRI
Hall of Fame Super Red
Re: Fractional PRI
Hi Ashok,
Note: Cisco CallManager does not support the configuration or use of a fractional PRI when you use it with MGCP. If fractional PRI is necessary you can use H.323 instead of MGCP.
How to Configure MGCP with Digital PRI and Cisco CallManager
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
MGCP and H.323 Voice Gateway Protocol Comparison
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a00806fedbe.shtml
The workaround for using a Fractional PRI with MGCP was perfectly detailed recently by Paul from Cisco;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cc17407/0#selected_message
Hope this helps!
Rob
Silver
Re: Fractional PRI
MGCP Config:
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
description ***PRI***
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ccm-manager fallback-mgcp
ccm-manager redundant-host x.x.x.x
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x x.x.x.x
ccm-manager config
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
Silver
Re: Fractional PRI
H.323 Config (for BRI in the UK)
isdn switch-type basic-net3
voice-card 0
no dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
h323
modem passthrough nse codec g711ulaw
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8 bytes 40
voice class h323 1
h225 timeout tcp establish 3
interface BRI0/0/0
no ip address
isdn overlap-receiving
isdn twait-disable
isdn point-to-point-setup
isdn sending-complete
isdn static-tei 0
voice-port 0/0/0
translation-profile incoming incoming
compand-type a-law
cptone GB
dial-peer voice 1 pots
tone ringback alert-no-PI
preference 1
destination-pattern 9T
progress_ind setup enable 3
progress_ind progress enable 8
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 999 pots
preference 1
destination-pattern 999
port 0/0/0
forward-digits all
dial-peer voice 5000 voip
destination-pattern 5...
no modem passthrough
voice-class codec 1
voice-class h323 1
session target ipv4:X.X.X.X
dtmf-relay h245-alphanumeric
fax rate 7200 bytes 48
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
VIP Super Bronze
Re: Fractional PRI
Re: Fractional PRI
Deji,
Need one more favour. Could you please give me the sample configs for each protocol?
Ashok.
VIP Super Bronze
Re: Fractional PRI
Re: Fractional PRI
Deji you simply rock! Just one more favour here - I see there are 2 options of configuring MGCP - Automatic, where the config gets downloaded from CCM & manual. Is there any particular reason for using any particular method?
Ashok.
VIP Super Bronze
Re: Fractional PRI
Using the CCM-Config command makes configuration easier..Some pople like it, some dont. I dont like it because sometimes it can give you problems.
Baiscally, the ccm-config methos configures the oruter automatically, and the manual one is manual
Re: Fractional PRI
Thanks again Deji for all the time you took out today to answer all my queries. Happy weekend!!
Ashok.
Re: Fractional PRI
Deji,
Ashok.
Silver
Re: Fractional PRI
MGCP Config:
controller E1 0/0/0
no ip address
encapsulation hdlc
no cdp enable
ccm-manager mgcp
ccm-manager config
mgcp
mgcp sdp simple
Silver
Re: Fractional PRI
voice-card 0
no dspfarm
voice rtp send-recv
voice service voip
h323
voice class codec 1
voice class h323 1
interface BRI0/0/0
no ip address
isdn twait-disable
isdn static-tei 0
voice-port 0/0/0
compand-type a-law
cptone GB
preference 1
direct-inward-dial
port 0/0/0
preference 1
port 0/0/0
forward-digits all
voice-class codec 1
voice-class h323 1
fax nsf 000000
no vad
Re: Fractional PRI
Thanks Darren for all the effort you took to help me out.
Ashok.
Re: Fractional PRI
Hi Ashok,
Hope this helps!
Rob
Silver
Re: Fractional PRI
Fractional E1 may not be supported with MGCP but its certainly configurable. Register your Voice Gateway with callmanager using the ccm-manager config command, but then remove this command and reconfigure the E1 as fractional. Works for me everytime.
Re: Fractional PRI
Thanks again Rob, happy weekend in advance - Ashok.
Re: Fractional PRI
Hi Rob,
Just curious here - is something similar ( Fractional PRI) possible with SIP gateways?
Ashok.
Re: Fractional PRI
Hey Ashok,
First off you are most welcome :) Can't wait for the weekend, it can't come fast enough!
I am not very familiar with SIP :( I do know that this clip is very applicable;
Capacity scaling: IP traffic is not bound to strict timeslot capacity of TDM trunks. Thus it is easier to scale the call capacity of Unified Communications trunks. Moreover, bandwidth can be dynamically allocated based on the application mix, number of sessions, etc. for optimum performance of the currently active applications.
From these excellent White Papers;
http://www.cisco.com/en/US/products/sw/voicesw/ps5640/prod_white_papers_list.html
Hope this helps!
Rob
Re: Fractional PRI
Thanks again Rob.
Ashok.
335
