Community Member
Frame Relay Lab Problem
I am using all Vwic-2mft's. I have the voice t1's making calls between sites using the PSTN. I am having an issue with getting frame relay up. I have matched the configuration from configs found on the web, and done my frame relay research. I am getting green link lights on all my frame relay interfaces but showing down, down. I cannot ping the local frame relay sub interface from the local router BTW. I am using the same pinout for both my t1 rj-45's, as well as my Frame relay rj-45's as well. Below is the configuration from my PSTN, and R3 routers.
PSTN:
interface Serial0/0/0:23
description ***Voice to R1***
no ip address
encapsulation hdlc
isdn switch-type primary-ni
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial0/0/1:0
description ***Data to R1***
no ip address
encapsulation frame-relay IETF
frame-relay lmi-type ansi
frame-relay intf-type dce
interface Serial0/1/0:23
description ***Voice to R2***
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/1:0
description ***Data to R2***
no ip address
interface Serial0/2/0:15
description ***Voice to R3***
no ip address
encapsulation hdlc
isdn switch-type primary-net5
no cdp enable
interface Serial0/2/1:0
description ***Data to R3***
no ip address
description frame-relay link to R2
no ip address
no fair-queue
clock rate 128000
frame-relay lmi-type cisco
frame-relay route 301 interface Serial0/0/1 103
description frame-relay to R1
no ip address
clock rate 128000
frame-relay route 102 interface Serial0/1/0 201
frame-relay route 103 interface Serial0/0/0 301
description frame-relay link to R3
no ip address
clock rate 128000
frame-relay route 201 interface Serial0/0/1 102
R3:
interface Serial0/1/0:15
description ***Voice to PSTN***
no ip address
encapsulation hdlc
no cdp enable
description ***Data to PSTN***
no ip address
interface Serial0/1/1:0 201 point-to-point
description frame relay to R1
ip address 177.0.201.2 255.255.255.252
ip ospf network point-to-point
snmp trap link-status
frame-relay interface-dlci 201
1 REPLY
Community Member
I forgot to mentions I am using the CCIE v3.0 lab topology. The PSTN has 3 vwic-2mft cards, 3 ports acting as voice t1's, and the other three acting as frame relay.
144
