French Locale for 8.5.1.12900-7
Team,
We have CUCM 8.5.1.12900-7 Unrestricted and recently we have added a site in AIX France in to our cluster located at Leeds. With reference to that we need to install User and Network French Locale in to our cluster. While checking in Cisco Product download section for 8.5.1, I do not see 8.5.1.12900-7 but I see only 8.5.1.2100-1. How to Install French Locale for 8.5.1.12900-7 in to our CUCM cluster. We are also running  UCCX 8.5.1.11003-32 in our cluster. Do I need to install French locale in to UCCX Server as well? Please share your thoughts.
Solomon.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
CUCM locale files do not need
CUCM locale files do not need to be identical, Cisco only releases one version for each base which can be used for any minor releases in that train.  This is different on Unity Connection where the versions have to be identical. So, simply use the  8.5.1.11003-32 version. In fact I have the exact some deployment on one of my customers.
HTH,
Chris
HTH,
Chris
 Thank you Chris. Infact cm
Thank you Chris. Infact cm-locale-fr_FR-8.5.1.2100-1.cop worked for our CUCM 8.5.1.12900-7. I am able to Install that locale in to our CUCM. So this locale will takes care of both User and Network French locales in my CUCM right???
Another question is, We also run Contact Center in our cluster. Currently we are running with 8.5.1.11003-32. Do I need to install locale even in UCCX as well for French Contact Center users.
Solomon.
In CCX you dont install the
In CCX you dont install the language locales, you turn specific ones on/off during install. The only thing the langugage changes is the ability to play system messages in different languages, if you have simple call flows and dont care about the system prompts you can simply upload your custom prompts in the French language.
Chris
Got it Chris, then what about
Got it Chris, then what about agent and supervisor apps. We need them to be in France. Is there a way where we can have them in French.
Solomon.
53
