Fresh install over CUCM pre-installed
Hi guys
I have to add a new CUCM subscriber in a cluster. The CUCM cluster have version 8.0.3 and the new hardware have the CUCM version 8.5. I tried do a fresh install of CUCM 8.0.3 in the new hardware,starting from a booteable DVD but it do not start the installation process, requires a packages and does not recognize the DVD. Please, see the picture.
Any idea?
TIA
Cristian.
1 ACCEPTED SOLUTION
Super Bronze
That most likely means that your new server is too new to run the 'old' CUCM version - ie.. that version of CUCM was built without the correct drivers for the new hardware which didn't exist/wasn't available or sold by Cisco at the time.
What model of server have you purchased?
And what exact version of 8.0(3)?
Check them against this matrix: http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Hall of Fame Super Silver
Cristian,
Are you sure the media is bootable?  Are you getting the "Check Media" screen first?
What are you doing to get to these screens?
You could try to format the drives in BIOS and try again.
Chris
Dear Chris
- Yes I´m sure that bootable
- No Check Media appears.
- I put the DVD(CUCM 8.0) , press F12 for Boot from DVD, then appear this screen. No start the kernel.
- Abouth the BIOS , How to do??
Cristian
Super Bronze
Aaron Harrison
Dear Aaron
you're right, the hw MCS7825I5K9CMD2 is supported for CUCM 8.5 and 8.6 only.
Thanks a lot.
Cristian
Re: Fresh install over CUCM pre-installed
upgrade the cluster then add the new server as this is more than likely a hardware compatibility issue with 8.0.
Ensure you run a bug scrub on the 8.5 or 8.6 version you would like to run.
353
