Community Member
Front end message on EXT
I have an EXT 12345 that when called I want to front end a message. After the message I want the call to ring the EXT. What is the best way to do this? I'm running CCM 5.1.
Bronze
Re: Front end message on EXT
You are probably asking about kind of IVR functionality. This can be done in a lot of ways, like Unity or IPCC Express etc.
Regards..
-Ashok.
With best regards... Ashok ----------- Pls kindly rate if helpful or answered your question.
Community Member
Is there a way to do it without Unity or IPCC
Just in CCM?
Community Member
We used to be able to remotely record announcements in IVR 5 since it was windows box; however, we have not been able to do it since upgrading to IVR 8 which is Linux based. Can you please tell me how would you do it in IVR 8?
164
