FSX for a CME 7.1
Hello all,
I was wondering if i can use an FSX port provided by my voip service provider's router and connect it to the CME 7.1 running on 2800 router  to test inbound and outbound calls ?
I know it can be done using a SIP trunk, i tried and worked, and obviously using a voice PRI which I'm not going to order to test the inbound and outbond calls..
Anyone have  done it, or is it even possible ?
Everyone's tags (4)
FSX for a CME 7.1
I can't see why not, if you would add a dailpeer (using SIP) on your CME router pointing to the IP address of your voip service provider's router, using the desired pattern, and vice versa. That should work.
provide some details (DN's and IP addresses) if you are unsure, so we can work out a config on the CME router.
regards
Dennis
Please remember to rate useful posts, by clicking on the stars below.
FSX for a CME 7.1
Dennis,
Thanks for the response!
I do not have access to the ISP router, its a regular VOIP router that provides home phone service..
Blue
FSX for a CME 7.1
To connect to service provider, you will need FXO port. Generally service provider will give FXO connectoin and we connect our analog phones to FXS ports.
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
FSX for a CME 7.1
How it can be connected to CME ?
Blue
FSX for a CME 7.1
It can be easily conected to CME.
Below document is having configuration for FXO FXS.
https://supportforums.cisco.com/docs/DOC-2906
CME configuration guide
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmenetwk.html
Ronak Patel
FSX for a CME 7.1
Thank you!!
410
