Full configuration of MGCP gateway and CUCM V6.0
Hello Sirs,
We have 2 MGCP IOS gateway connected over WAN connection and through PSTN and the Head Quarter is connected with CUCM v6.0
I need the full configuration of the MGCP gateways.
Thanks a lot.....
Re: Full configuration of MGCP gateway and CUCM V6.0
Try this:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f8b31.shtml
It's not quite CUCM 6.0, but it's as close of a full configuration as I know of. And, they're not that much different.
Who knows, you might learn something :)
hth,
nick
If we want to use H.323 gateway what will be the difference.
Thanks a lot nick.
WAY different, they're as day and night
Cisco IOS H.323 Configuration Guide
http://www.cisco.com/en/US/partner/docs/ios/12_3/vvf_c/cisco_ios_h323_configuration_guide/old_archives_h323/323confg.html
Cisco IOS H.323 Gateway Configuration for Use with Cisco CallManager
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080094636.shtml
Dial Peer Configuration on Voice Gateway Routers
http://www.cisco.com/en/US/partner/docs/ios/12_3/vvf_c/dial_peer/dpeer_c.html
java
if this helps, please rate
java
www.cisco.com/go/pdi
Sorry java,
i cant get access to this links
Hall of Fame Super Silver
Hello Tito,
you may need to change
/US/partner/ in /US/customer/ in all the URLs
this depends on your CCO account
Hope to help
Giuseppe
Hi Tito,
With MGCP, you can use autoconfiguration and CUCM controls the dial plan. In a way, all of the voice stuff that happens goes way over the router's head, and it doesn't see much at all.
In H323, the router does everything. It controls all of the dial plans, IP addresses, translation, signaling options, blocking of calls, everything.
MGCP can be implemented on a gateway in 3-4 lines of configuration.
H323 will be around 30 for a simple setup, possibly hundreds for something more involved. Plus, it will be much more troubleshooting if you don't know what you're doing.
If you'd like more details, you can start clicking and looking at java's links.
hth,
nick
150
