FWD ALL to another extension-No Answer / VM option
Is there away to fwd all calls to phone A to phone B and if phone B does not answer, the call goes into Phone B's voicemail and not Phone A's?
Both phone A and B have voicemail accounts.
7942 Phone
Unity Connections 8.5
CCM 8.5
Troy
1 ACCEPTED SOLUTION
right now, about 10 threads below yours, lies the answer:
https://supportforums.cisco.com/thread/2139244?tstart=0
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
1 REPLY
java
java
165
