Fwd No Coverage, Fwd Unregistered with EM
With Extension Mobility enabled, do these settings have any significance ? I suspect they will just match a DN that is not logged in ? Or will they indentify (for example) where a DN was unregistered but not logged out cleanly (like a site going into SRST) ?
1 REPLY
Re: Fwd No Coverage, Fwd Unregistered with EM
no coverage works, but as with any other phone only when registered.
if the profile is not logged in then it will use the unregistered config
java
if this helps, please rate
java
www.cisco.com/go/pdi
147
