Community Member
FWD selected numbers
hi
i have 8XXX as my internal DNs i want to let all incoming 8XXX to my ip phone while all external numbers from outside enterprise to be forwarded to an extension/mobile,..
is this possible, how?
thanks
Green
Re: FWD selected numbers
i UNDERSTAND that you want to send INCOMING CALLED numbers out of range 8xxx (ie 7999) to your mobile right?
You can change the called number using a Translation Pattern or a translation rule in GW and create a Route Pattern with the new CALLED NUMBER that send it where you want,
or using Mobility you can do that also.
Community Member
lets say my company has 8XXX as our internal DNs, my DN is 8888 i wanna to let any one internally (from any 8XXX) to mine(8888) to reach me
while all other external numbers from pstn (outside my company) to be forwarded to another extension,mobile,...
hope its clear now, how can this be achieved?
100
