Community Member
FXO BINA
Hi.
The FXO voice card by Cisco don't use BINA?
How can I do to my phones know who's calling using FXO ports?
Hall of Fame Super Gold
Re: FXO BINA
BINA (B Identifica Numero A), is the Brazilian version of the DTMF-based caller-id schemes, in theory the correct version is automatically set based on the cptone parameter, so it's worth a try.
If it doesn't work, I understand there are devices that convert BINA to regular standard.
Community Member
Re: FXO BINA
Thanks Paolo.
Community Member
Re: FXO BINA
Hi Paolo
Here in Brazil, the BINA is with DTMF and not FSK. How can I know if the FXO Card support caller-id DTMF?
Peterson
205
