FXO BUSY --> Calls rejected with cause code 44
I have a next scenary:
PSTN --> E1 GW (2951) --> VG --> Phone analog.
The numbering published enters the PSTN to gw with a dial-peer sending it all to the VG, and is eg that by trunk-groups and dial-peers is what sends the llaamda ports associated with these trunks
When those ports associated this busy, the vg, gw returns to the network code 44 Cause i = 0x80AC - Requested circuit / channel not available
How could return to the PSTN, the user busy code?
I attached configurations, GW and Vg
______________________Debug VG___________________
065231: Nov 17 09:56:56.249: //-1/xxxxxxxxxxxx/H323/cch323_h225_receiver: Received msg of type SETUPIND_CHOSEN
065232: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/setup_ind: callingNumber[XXXXXXXXX] calledNumber[YYYYYYYYY]
065233: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/setup_ind: ---- calling IE present
065234: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/setup_ind: ====== PI = 3
065235: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/setup_ind: Receive: infoXCap 16
065236: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/setup_ind: Receive: infoXCap ccb 16
065237: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/setup_ind:
setup_ind: is_overlap = 0, info_complete = 0
065238: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/cch323_h225_receiver: SETUPIND_CHOSEN: src address = 192.168.1.11; dest address = 192.168.1.13
065239: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/run_h225_sm: Received event H225_EV_SETUP_IND while at state H225_IDLE
065240: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/common_idle_setupInd_hdlr: full match is found
065241: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_SETUP state
065242: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/cch323_create_incoming_callinfo_block: peer 10E1848C, voice_peer_tag 1, ccb: 127BE278
065243: Nov 17 09:56:56.249: //1321/8459612A82AE/H323/cch323_h225_handle_deferred_ind: UnBuffering deferred indications
065244: Nov 17 09:56:56.253: //1321/8459612A82AE/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_SETUP
065245: Nov 17 09:56:56.253: //1321/8459612A82AE/H323/cch323_h225_send_release: Cause = 44; Location = 0
065246: Nov 17 09:56:56.253: //1321/8459612A82AE/H323/cch323_h225_send_release: h225TerminateRequest: src address = 192.168.1.11; dest address = 192.168.1.13
065247: Nov 17 09:56:56.253: //1321/8459612A82AE/H323/cch323_h225_set_new_state: Changing from H225_SETUP state to H225_IDLE state
065248: Nov 17 09:56:56.253: voice_file_acct_initiate_dump_to_file: Both file modes have failed in earlier attempt
065249: Nov 17 09:56:56.253:  Use file-acct reset when the problem is recovered
065250: Nov 17 09:56:56.253: //1321/8459612A82AE/H323/run_h245_iwf_sm: received IWF_EV_H245_DISCONN while at state IWF_IDLE
065251: Nov 17 09:56:56.253: //1321/8459612A82AE/H323/defaultHdlr: DEFAULT: Received IWF_EV_H245_DISCONN in state IWF_IDLE
065252: Nov 17 09:56:56.253: //-1/xxxxxxxxxxxx/H323/validate_crv: No CCB for crv: 0x852D
______________________Debug GW_____________________________
011219: Nov 17 09:57:24.271: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x007C
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Calling Party Number i = 0x0183, 'XXXXXXXXX'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, 'YYYYYYYYY'
                Plan:ISDN, Type:National
011220: Nov 17 09:57:24.271: ISDN Se0/0/0:15 Q931: Received SETUP  callref = 0x807C callID = 0x02AE switch = primary-net5 interface = User
011221: Nov 17 09:57:24.283: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x807C
011226: Nov 17 09:57:24.307: ISDN Se0/0/0:15 Q931: TX -> DISCONNECT pd = 8  callref = 0x807C
        Cause i = 0x80AC - Requested circuit/channel not available
011227: Nov 17 09:57:24.419: ISDN Se0/0/0:15 Q931: RX <- RELEASE pd = 8  callref = 0x007C
011228: Nov 17 09:57:24.419: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x807C
Thanks you.
Everyone's tags (1)
97
