FXO CALL BLOCKING
In my network cisco ip phones are controlled by cme and there is 4 fxo ports and pri and in this fxo port have configured connection plar how to enable call blocking through this fxo because in currrent scenario user can make blocked calls through this fxo port
1 ACCEPTED SOLUTION
Hello,Try implementing the
Try implementing the LPCOR to block calls. PFB some reference docs and you can find more on cisco/google
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/command/reference/cme_cr/cme_l1ht.html#wp1063898
https://supportforums.cisco.com/discussion/11411236/lpcor-fac-issue-voice-ports-cme85
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Br,
Nadeem
Hi,You can use COR lists to
You can use COR lists to prevent the users on making unwanted calls.
In this case the ephone-dn will have the incoming COR lists assigned to them and the dial-peers for FXO and PRI will have outgoing COR list applied to it.
To make a successful call incoming COR list should be equal or superset of outgoing COR list.
Hence the dn's that should have access should have equal or superset and the dn's whom to block should have subset COR list .
You can learn how to configure below:
http://www.cisco.com/c/en/us/support/docs/voice/call-routing-dial-plans/42720-configuring-cor.html
Divjot Nanda
**Please rate useful posts**
in telephony service i have
in telephony service i have used all hours block patterns but it is not getting applied am going through the documents
Hi,Kindly let us know what is
Kindly let us know what is the exact requirement. are you looking for time based blocking or blocking PSTN calls to certain users.
Divjot Nanda
**Plese rate useful posts**
Hi My requirement is that
My requirement is that want to block all users calling certain countries  and i did through time based blocking but it is not working while calling through FXO but working fine through PRI
83
