FXO call disconnect problem after 180s
I have a voice gateway with FXO ports and the calls are disconnecting after 180 seconds.
With "debug voice vtsp all" enable:
lpvgw01#
Aug 10 18:16:15.324: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_ring_noan_timer_start:
Timer Start Time=118723786, No Answer Timer Value=180000(ms)
Aug 10 18:16:15.324: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/act_setup_pend_alert:
Ringback Indication=FALSE, Ring Timeout=180(s)
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_check_cb:
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_check_cb:exit@1355
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_status_cb:
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_save_fax_config:
Fax Relay=DISABLED - 'fax rate disabled' set (dial-peer)
Primary Fax Protocol=IGNORE_FAX_RELAY, Fallback Fax Protocol=IGNORE_FAX_RELAY
Fax Relay CM Suppression :=ENABLED, Fax Relay ANS Suppression :=DISABLED
Fax Parameters Set By=Dialpeer, Peer=1
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_set_fax_feat_param:
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_save_tty_config:
Save TTY configuration
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_set_tty_feat_param:
Set TTY feat parameters
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_CC_DO_CAPS_IND]
Aug 10 18:16:15.328: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_peer_event_cb:
Event=E_DSM_CC_CAPS_ACK
Aug 10 18:16:15.368: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_CC_CAPS_IND]
Aug 10 18:16:15.368: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_peer_event_cb:
Event=E_DSM_CC_CALL_MODIFY
Aug 10 18:16:15.372: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_feature_notify_cb:
Feature ID=0, Feature Status=1
Aug 10 18:16:15.372: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_reactivate_ringback:
Aug 10 18:16:15.372: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_reactivate_ringback:exit@1147
Aug 10 18:16:23.956: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_media_event_cb:
Event=E_DSMP_DSP_ANS_SUP
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_RING_NOAN_TIMER]
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/act_ring_noan_timer:
No Answer Timer Expired
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_cc_call_disconnected:
Cause Value=19
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_set_release_source:
Release Direction=Internal, Release Source=Internal Release-PSTN
Aug 10 18:19:15.326: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_dsm_bridge_status_cb:
Aug 10 18:19:15.330: //1041/808327E15C00/VTSP:(0/1/0):-1:1:1/vtsp_process_event:
[state:S_SETUP_REQ_PROC, event:E_CC_DISCONNECT]
lpvgw01#
Aug 10 18:16:15
Aug 10 18:19:15
This is the configuration of the FXO port:
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory answer dualtone
cptone BR
timeouts call-disconnect 1
timeouts wait-release 1
timing hookflash-out 50
connection plar 10002
I already configured the "timeouts ringing infinity" but doesn't work.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: FXO call disconnect problem after 180s
It's telling you very cleary...
you need
no supervisory answer dualtone
The, supervisory disconnect likely won't work as that, but that's another issue.
you need
I removed this configuration and issue is resolved.
The supervisory disconnect of the call appears doesn't have been impaired.
Thanks.
Very good, thanks for the nice rating and good luck!
422
