FXO Call
Dears,
May be what i am asking is funny, but it has been asked to me.
I have a FXO card with 4 ports in router with 4 numbers , when PSTN user dial on port 1 on number 22222222 and if it is engaged , the pstn user should be transfered on port 2 on  number 22222223.
1 ACCEPTED SOLUTION
If you mean incoming calls,
If you mean incoming calls, and you have 4 separate FXOs, each one with their own DN, you should be asking you telco about this, most likely the answer will be no, at least with the setup you have.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Thanks Jaime,I will contact
Thanks Jaime,
I will contact to telco and reply on this thread.
Dear Jaime,Thanks for the
Dear Jaime,
Thanks for the reply, I have rated for the post.
38
