Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
fxo caller-id issue
Hello!
Could you please help me!
I have the following topology
PST <-> FXO(UC520)<->SIP trunk (CUCM 9.1)
uc500-advipservicesk9-mz.151-2.T4
The folowing configuration of the port
voice-port 0/1/2
supervisory disconnect dualtone mid-call
supervisory custom-cptone custom-cptone
cptone RU
timeouts wait-release 1
timing hookflash-out 50
timing guard-out 1000
connection plar opx 6309
caller-id enable
Caller ID doesn't display on the ip-phone.
Tried to add the folloving commands:
ring number 2
caller-id alerting ring 2
it did not help
"debug vpm signal" in attachment
Will appreciate any suggestion.
Thank you in advance!
Hall of Fame Super Gold
Re: fxo caller-id issue
Update IOS to latest and check again.
fxo caller-id issue
Hello Paolo!
Thank you for your reply!
Actually not because we don't have analog phone in our branch office  but telco said they provide caller id.
VIP Super Bronze
fxo caller-id issue
Denis,
Telco is correct, the caller id is presented...
syslog@9 s_sn="7914" s_tc="12815" s_dc="1827"]: 007860: *Nov  5 15:18:14.828 KRODAR: [0/1/3] get_fxo_caller_id:Caller ID received. Message type=128 length=27 checksum=7F
[syslog@9 s_sn="7915" s_tc="12816" s_dc="1828"]: 007861: *Nov  5 15:18:14.832 KRODAR: [0/1/3] Caller ID String 80 18 01 08 30 32 32 36 31 36 30 33 02 09 61
Do you know what the caller ID number is?
I suggest you use an analogue phone to see when the caller id is presented..after the first ring or second ring etc
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
fxo caller-id issue
actually I call from 88127403010 but in logs everytime I see the different the caller id string.
for example
Caller ID String 80 18 01 08 30 32 32 36 31 38 33 35 02 09 61
Caller ID String 80 18 01 08 30 32 32 36 31 39 32 33 02 09 61
Caller ID String 80 18 01 08 30 32 32 36 31 39 32 34 02 09 61
all calls made from the same number 88127403010
I also tried this
ring number 2
no luck
fxo caller-id issue
Please try:
2811(config-sip-ua)#timers buffer-invite ?
  <50-5000>  buffer-invite timer value in msec
I would setup 2000 first, then increase the timer if neccesary.
I'm suspecting the Call is received on FXO and forwarded to SIP Trunk faster than the caller id is received from TELCO.
Give it a try and let us know.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
fxo caller-id issue
Hello Jorge!
Thank you for your response!
I tried the value 2000; 3000; 4000; 5000 but it doesn't help. Anyway I have unknown number on my ip-phone.
fxo caller-id issue
Interesting...
Ok, please capture:
deb voice ccapi inout
deb vpm signal
deb ccsip messages
Please share the "show run" and "show version"
Jorge Armijo
Jorge,
logs in attachment
It will be better if you capture all the debugs at the same time for the same call.
Jorge Armijo
I'm sorry
in this attachment all debugs at the same time
deb vpm signal
deb ccsip messages
Debugs are incomplete.
Remove:
cptone RU
Apply:
caller id alerting ring 4
Collect all the debugs again and let us know.
Jorge Armijo
Hello Jorge!
I did as you said
Removed:
cptone RU
Applied:
Nothing changed
New logs in attachment
fxo caller-id issue
I don't see the logs, can you upload them again?
Jorge Armijo
461
