FXO caller-id
I'm setting up CME4.1 with a vic-2fxs and vic-2fxo.
I can get both working with IP and analogue phones.
My issue is that whenever I get a call from the PSTN over FXO to an analogue phone, there is no caller-id - the phone just says 'Call'. I've read the cisco docs which advise that you need 'caller-id enable' on both the FXO and FXS port.
I can get this command onto the FXS port which I'm guessing will give my caller-id out, but I cant get the command onto the FXO port which I assume is the one that will pick up the caller-id siganl for the incomming PSTN call.
Here is my configuration for the voice ports:
voice-port 1/0/0
supervisory disconnect dualtone mid-call
cptone GB
timeouts call-disconnect 5
timeouts wait-release 5
connection plar 260492
voice-port 1/0/1
voice-port 1/1/0
caller-id enable
voice-port 1/1/1
dial-peer voice 201 pots
destination-pattern 9T
port 1/0/0
dial-peer voice 202 pots
destination-pattern 260492
port 1/1/0
Super Bronze
Re: FXO caller-id
Do you mean you don't have any 'caller-id' commands available under your FXOs? Even if you type 'caller?'
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: FXO caller-id
Hi Aaron
Yes, thats correct, if I do "caller ?" under my FXO then I just get an unregonised command response.
I'm running the Advanced Enterprise Services IOS version 12.4(11)XJ4 with CME 4.1.0.1, so its not a really old IOS.
P.S. Sorry to the web-admin - just noticed that I've posted this under Video over IP and not Voice over IP.
Re: FXO caller-id
Hello Robert,
The command that you are looking for is "caller-id enable" under the voice-port configuration and it should available in the IOS that you are currently using
Please check this link for further information
http://tools.cisco.com/Support/CLILookup/cltSearchAction.do?Application_ID=CLT&IndexId=IOS&IndexOptionId=123&SearchPhrase=%22*%22&Paging=25&ActionType=getCommandList&Bookmark=True
Walter   Solano
CCNA Voice
UCCX   Specialis
Re: FXO caller-id
Thanks Walter, but the problem is that none of the caller-id comands under the FXO port are recognised.
I can get the 'caller-id enable' command for the FXS port but not the FXO port.
Re: FXO caller-id
Robert,
Do you have the output of the "show diag", I would like to see the model of your FXO card.
Re: FXO caller-id
Here is the output of my 'show diag' for the vocie ports......
Slot 1:
        4 PORT Voice PM for C2600 Port adapter
        Port adapter is analyzed
        Port adapter insertion time unknown
        EEPROM contents at hardware discovery:
        Hardware revision 1.1           Board revision H0
        Serial number     21458853      Part number    800-02491-02
        FRU Part Number     NM-2V=
        Test history      0x0           RMA number     00-00-00
        EEPROM format version 1
        EEPROM contents (hex):
          0x00: 01 65 01 01 01 47 6F A5 50 09 BB 02 00 00 00 00
          0x10: 88 00 00 00 00 08 30 17 FF FF FF FF FF FF FF FF
          0x20: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x30: FF FF FF FF FF FF FF FF FF FF FF FF
        VIC Slot 0:
        FXO Voice daughter card (2 port)
        Hardware revision 1.1           Board revision J0
        Serial number     22694650      Part number    800-02495-01
                                Connector type    Wan Module
          0x20: 01 0D 01 01 01 5A 4A FA 50 09 BF 01 00 00 00 00
          0x30: 98 00 00 00 00 12 13 01 FF FF FF FF FF FF FF FF
        VIC Slot 1:
        FXS Voice daughter card (2 port)
        Hardware revision 1.1           Board revision C0
        Serial number     9886098       Part number    800-02493-01
          0x20: 01 0E 01 01 00 96 D9 92 50 09 BD 01 00 00 00 00
          0x30: 60 00 00 00 98 08 24 01 FF FF FF FF FF FF FF FF
444
