08-16-2013 11:38 AM - edited 03-16-2019 06:54 PM
Dears,
I need to setup a small company for 20 users in which for IP telephony on voice router 4 port FXO card has been ordered, I want to confiure the 4 port FXO card for internal users to dial outside to PSTN.
Can anybody route me to configuaration example or any post linking similar to my request to achieve the above.
Solved! Go to Solution.
08-17-2013 12:08 AM
All you need are dialpeers, have you reviewed the CME config guide and dial peer configuration guides??? If search CSC youll find plenty of examples
08-16-2013 12:39 PM
Is this going to be a GW of off centralized CUCM or standalone CME system? Where will the phones be registered to?
Chris
08-16-2013 01:20 PM
Hello Chris,
It is standalone CME system, the phone will be registered to CME, (C2921-CME-SRST/K9) router. The FXO card is installed in this router
08-16-2013 04:48 PM
Anybody can help me for the above query
08-17-2013 12:08 AM
