FXO Card 4 Port
Dears,
I need to setup a small company for 20 users in which for IP telephony on voice router 4 port FXO card has been ordered, I want to confiure the 4 port FXO card for internal users to dial outside to PSTN.
Can anybody route me to configuaration example or any post linking similar to my request to achieve the above.
1 ACCEPTED SOLUTION
Re: FXO Card 4 Port
All you need are dialpeers, have you reviewed the CME config guide and dial peer configuration guides??? If search CSC youll find plenty of examples
java
if this helps, please rate
www.cisco.com/go/pdi
Hall of Fame Super Silver
FXO Card 4 Port
Is this going to be a GW of off centralized CUCM or standalone CME system? Where will the phones be registered to?
Chris
Re: FXO Card 4 Port
Hello Chris,
It is standalone CME system, the phone will be registered to CME, (C2921-CME-SRST/K9) router. The FXO card is installed in this router
Re: FXO Card 4 Port
Anybody can help me for the above query
Re: FXO Card 4 Port
java
252
