Community Member
FXO Cards stops working every few days
Hi All
I have 1751v with cme 4.01 and ios 12.4(11)T1. Everything setup and working fine except that the fxo card (vic-2fxo) seems to stop working every few days. No calls can be received or made. A reboot of router always cures it.
Any ideas?
Hall of Fame Super Gold
Re: FXO Cards stops working every few days
Bad, bad. Possible data structure trashing. I suggest you open a case with the TAC, be prepared to supply all the requested traces, request escalation, and possibly a bug to be opened.
Community Member
What are you implying? Bad FXO card? Bad Router? Bad Config?
Buggy IOS software.
Community Member
Oh right - should I just download a different version then? Any suggestions on which version?
The thing is that you are already at latest, or almost, with 12.4(11)T1. It would reasonable to expect that release to work or be fixed.
The only more recent image you could try would be 12.4(11)XJ1 but I'm not aware of any bug fix in the area of FXO ports.
130
