FXO: CCM4.2, Gateway H323, Cannot hear the othe side
adham_tahoun
I am facing a weird problem here; I had configured 3845 Router to be work as H.323 gateway for Cisco Unified Communication Manager 4.2. The interface to the PSTN is FXO - temporarily - until E1 is received.
If I called the Analog line, I can receive the call on an extension, but I cannot hear the calling party (other side)
If I called outside, I can reach my destination but again, I cannot hear the called party (the other side) but he can hear me perfectly. I even cannot hear any progressive tone until the call is answered.
I am not behind a firewall, all the ports are open, Router and CCM are on the same
VLAN.
The Gateway configuration:
User Access Verification
Password:
VG>en
Password:
VG#sh run
Building configuration...
Current configuration : 2301 bytes
version 12.4
service password-encryption
hostname VG
boot-start-marker
boot-end-marker
!card type command needed for slot 1
no aaa new-model
no network-clock-participate slot 1
ip cef
voice-card 0
no dspfarm
voice-card 1
no dspfarm
trunk group FXO
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
h323
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no keepalive
interface GigabitEthernet0/1
ip address 10.1.1.15 255.255.255.0
duplex auto
speed auto
media-type rj45
no keepalive
ip http server
no ip http secure-server
control-plane
voice-port 0/0/0
trunk-group FXO
connection plar opx 1066
description Tel: 5031396
caller-id enable
voice-port 0/0/1
trunk-group FXO
description Tel: 5031394
caller-id enable
voice-port 0/0/2
trunk-group FXO
description Tel: 5031397
caller-id enable
voice-port 0/0/3
voice-port 0/1/0
voice-port 0/1/1
voice-port 0/1/2
voice-port 0/1/3
voice-port 0/2/0
voice-port 0/2/1
voice-port 0/2/2
voice-port 0/2/3
voice-port 0/3/0
voice-port 0/3/1
voice-port 0/3/2
voice-port 0/3/3
dial-peer voice 1 pots
trunkgroup FXO
destination-pattern .T
dial-peer voice 2 pots
trunkgroup FXO
destination-pattern 9[2-9]......
forward-digits 7
dial-peer voice 3 pots
trunkgroup FXO
destination-pattern 9T
forward-digits all
dial-peer voice 10 voip
preference 1
destination-pattern 10..
session target ipv4:10.1.1.3
dtmf-relay h245-alphanumeric
codec g711alaw
line con 0
password 7 070C285F4D06
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
password 7 13061E010803
login
scheduler allocate 20000 1000
end
VG#
Thanks in Advance
gogasca
Level 10
Level 10
