08-14-2013 09:42 AM - edited 03-16-2019 06:51 PM
I have a huawei lte e5172 router. It come with a telephone jack. An analog phone connected to this port works fine.
My problem is if I connect this port to an fxo port in a cisco 2801 router.
The 2801 with the vic card do not detect that there is a line connected to it. not possible inbound nor outbond calls.
The fxo port is fine, if I connect another line from the pstn or to a sip gateway works fine.
Both the LTE modem and the fxo port in the 2801 works with other brands but not between them.
I need some help with this.
Thanks.
08-14-2013 09:53 AM
have you tried both loop start and ground start signalling?
Router(config)# voice-port slot/subunit/port
Router(config-voiceport)# signal loop-start | ground-start
http://www.cisco.com/en/US/docs/ios/12_2/voice/configuration/guide/vvfport.html#wp1054950
08-14-2013 10:23 AM
Groud start is only for certain special order lines in the USA. It does not apply to any other situation.
08-14-2013 11:09 AM
Hello Chris, its me, Rafa!.
Yes, I done everything, but nothing works with this LTE modem.
I have done the same with other analog lines and with other cable-modem with fxs ports connected to the 2801 and works fine.
08-14-2013 10:23 AM
"debug vpm signal" with "term mon".
08-14-2013 01:03 PM
Sometimes the outgoing calls goes well, but for incoming calls the caller only hear the ring tone, but the router never answer.
the port configuration is:
voice-port 0/1/1
connection plar 5000
caller-id enable
this is the debug command which shows a succesfull outgoing call:
Aug 14 19:47:23.064: htsp_timer_stop3 htsp_setup_req
Aug 14 19:47:23.068: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Aug 14 19:47:23.068: [0/1/1] set signal state = 0xC timestamp = 0
Aug 14 19:47:23.068: htsp_timer - 1300 msec
Aug 14 19:47:23.268: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_0100]fxols_disc_clear
Aug 14 19:47:23.272: htsp_timer_stop2
Aug 14 19:47:23.272: htsp_timer - 1300 msec
Aug 14 19:47:23.320: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_DSP_SIG_1100]fxols_power_denial_detected
Aug 14 19:47:23.324: htsp_timer2 - 1000 msec
Aug 14 19:47:23.324: htsp_timer_stop
Aug 14 19:47:24.324: htsp_process_event: [0/1/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER2]fxols_power_den_disc
Aug 14 19:47:24.324: htsp_timer_stop
Aug 14 19:47:24.324: htsp_timer_stop2
Aug 14 19:47:24.324: [0/1/1] set signal state = 0x4 timestamp = 0
Aug 14 19:47:24.328: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_HTSP_RELEASE_REQ]fxols_onhook_release
Aug 14 19:47:24.596: htsp_process_event: [0/1/1, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Aug 14 19:47:24.596: htsp_timer - 125 msec
Aug 14 19:47:24.724: htsp_process_event: [0/1/1, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Aug 14 19:47:24.724: htsp_timer - 10000 msec
Aug 14 19:47:24.724: htsp_timer3 - 5600 msec
Aug 14 19:47:24.724: [0/1/1] htsp_start_caller_id_rx:BELLCORE
Aug 14 19:47:24.724: htsp_start_caller_id_rx create dsp_stream_manager
Aug 14 19:47:24.724: [0/1/1] htsp_dsm_create_success returns 1
Aug 14 19:47:30.324: htsp_process_event: [0/1/1, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
Aug 14 19:47:30.324: htsp_timer_stop3
Aug 14 19:47:34.724: htsp_process_event: [0/1/1, FXOLS_RINGING, E_HTSP_EVENT_TIMER]fxols_ringing_disc
Aug 14 19:47:34.724: htsp_timer_stop3
Aug 14 19:47:34.724: [0/1/1] htsp_stop_caller_id_rx. message length 0
Aug 14 19:47:34.724: [0/1/1] htsp_dsm_close_done
there is no debug output for the incoming call.
08-14-2013 01:30 PM
You can try configuring a different cptone, however the debug indicates many problems including no loop current and ringing detected while doing an outgoing calls, so likely that is not going to work anyway.
08-14-2013 01:43 PM
Its a wierd problem related with the LTE modem. This modem has voice system based in SIP.
supposedly it has a normal fxs port, but there are several problems, for example if the outgoing call goes fine, the following problem is the dtmf.
I have to talk with the provider to see how solve those issues.
08-14-2013 01:47 PM
They will lilkely tell you that if a phone works, their responsability ends there.
08-29-2013 10:23 AM
The provider said that may be is a problem with the 48Volts, because the LTE modem use a 9V AC/DC adapter, and its possible that this device is not able to produce the range of voltages requiered by the vic2 fxo port.
Something weird happened, I confiured the fxo port (in UC520) with anwer supervision (supervisory answer dualtone & supervisory disconnect dualtone mid-call). It worked for several attempts. After that has been imposible get this work again.
With the 2801 It never worked.
08-29-2013 12:37 PM
Telephony devices use DC-DC converters. They can produce an higher voltage than the power supply, even if not full 48v. However whatever it does, it is not good enough for the 2801.
