Community Member
fxo config issue
I am trying to configure a FXO port on CCME 4.1
Calls are coming in o.k but when I disconnect the call from the Callmanager express side, the other party stays connected.
Also I cannot make outgoing calls, I have pasted the relevant detaills below.
dial-peer voice 9 pots
description - Mobile -
destination-pattern 907.........
port 0/0/0
forward-digits 11
voice-port 0/0/0
signal groundStart
cptone GB
connection plar opx 3006
impedance complex2
Re: fxo config issue
Hi friend,
May be you can read about this:
Understanding FXO Disconnect Problem:
-- adrián.
Community Member
thanks for the info but I have read ittried that and still no joy, the main concern is not being able to dial out at all
Hall of Fame Super Gold
May be the port is stuck due to a call remained up. Reload the router and see if you're able to call out.
Community Member
yes I have done that as well.
when i run a sh voice port summary whilst dialling out, I can see the fxo port go off hook
but then nothing happens i do not get any sound
Is the line active ? Check with a phone.
Beside, if not active, the routerl will tell you that as "power denial" with "debug vpm signal" and "term mon".
Community Member
I have also tried with an analogue phone and it can make outgoing calls, what I have done is completely wipe the config and just used the bare min config with one phone registered, that has worked fine, so obviously i have some misconfig somewhere, I will add a bit at a time
and see wht happens,
many thanks for your help
