FXO-Configuration with cisco router-2901-MGCP GW-cucm 9.1.2
I have configured FXO port with analog telephony line on cisco 2901 router.
I have cucm 9.1.2 MGCP GW connected to this router
I have registerd the FXO port with my CUCM  using 0/1/1 port connected it to router.
Calls are working fine both ways incoming as well as outgoing below are 2 issues I am not able to fix
1. If an external call is coming caller ID not displayed  but customer already has Caller ID facility I can see it on analog phone when I get a call on same line. but  "0" is displayed on my IP phone or some times "unkown number"
2.If an external caller calls and after few ring he disconnects before I pick up the call on IP phone still I can see the IP phone ringing It should also stop ringing.
On the router I have configred
voice-port 0/1/1-----------------------------> (on FXO port cisco 2901 router)
 input gain -6-----------------------------> also tried 14
 compand-type a-law
 cptone IN
 timeouts interdigit 3
 timeouts call-disconnect 1
 timeouts wait-release 1
 timing hookflash-out 50
 timing guard-out 1000
 connection plar 4002-------------------> (my IP phone extension also)
 caller-id enable
 caller-id mode DTMF
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocation
Still no Go Please help Is there any other command which can fix my issue?
Rgds,
Ajith
Ajith,Check if you have
Ajith,
Check if you have enabled the parameter "Enable Caller Id" in the gateway page
If you connect the analog phone at what instance do you see the caller ID (i.e). after one ring or after connect, etc..
Also provide the following outputs
show version
show voice port 0/1/1
Debug voice ccai inout
Debug voip vtsp all
Debug vpm signal
Debug mgcp packets
Niran
Dear Niranjan,   "Enable
Dear Niranjan,
  "Enable Caller Id" in the gateway is alreayd present
I had tried  those commands and I have putty-logs I will share with you tomo..
rgds,
ajith
Hi NiranjanPFA putty logs I
Hi Niranjan
PFA putty logs I can see in
*Aug 14 11:06:50.230: [0/1/1] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
*Aug 14 11:06:50.230: [0/1/1] get_fxo_caller_id:Caller ID receive failed.  parseCallerIDString:no data.
*Aug 14 11:06:50.230: [0/1/1] get_local_station_id calling num= calling name= calling time=08/14 11:06  orig called=
*Aug 14 11:06:50.234: //-1/xxxxxxxxxxxx/VTSP:(0/1/1):-1:-1:-1/vtsp_allocate_cdb:
   CDB=0x3EEEA800
   CDB=0x3EEEA800
In above logs i can see  caller ID received failed and no string data
also in below log it says -->   X: 0
LIC-VOICE#
*Aug 14 11:06:39.774: MGCP Packet sent to 10.240.19.6:2427--->
NTFY 315225120 *@LIC-VOICE MGCP 0.1
X: 0
O:
*Aug 14 11:06:39.774: MGCP Packet received from 10.240.19.6:2427--->
200 315225120
X: 0
May be this is the reason I m getting 0 displayed on my ip phone when an incoming call is coming
Rgds,
Ajith
Any update ????
Any update ????
Hi Ajith,Try the following
Hi Ajith,
Try the following commands:
mgcp persistent offhook
then:
no mgcp
mgcp
voice-port x/x/x
sh
no sh
FYI, https://supportforums.cisco.com/discussion/11185531/cucm8-caller-id-issue-fxofxs-using-mgcp#3404786
Niran
VIP Gold
Hi Ajith,Plz attach requested
Hi Ajith,
Plz attach requested logs or try to change the gateway to H323 gateway. I have seen problems with caller id in mgcp gateways but not with H323 gaetway.
Suresh
782
