FXO Disconnect Issue
I use C3945, in that router running IVR on Router with tcl script for incoming call. I've a problem with disconnect on FXO. Sometimes FXOs remain off-hook even if the incoming call is ended. When I input "show call active voice brief", I saw the duration of the call 1d2h.
Here is the syntax on FXO port
voice class custom-cptone Disconnect
dualtone disconnect
  frequency 450
  cadence 363 343
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone Disconnect
cptone ID
timeouts call-disconnect 1
timeouts ringing 10
timeouts wait-release 1
timing hookflash-out 50
description 8883106
voice-port 0/0/3
cptone ID
timeouts ringing 10
description 8883107
When the FXOs shut and no shut, FXOs running well for a while, but the ports will remain off-hook again.
Did i missed something ?
BR,
Manalu
Hall of Fame Super Gold
Probably the tone configuration is wrong.
Re: FXO Disconnect Issue
I've captured the packet RTP disconnect tone with wireshark and convert it to file audio (extension au).
I attach the file. Please advice what is the value of the tone ?
VIP Super Bronze
Most likely your frequency and cadence are set incorrectly. You need to find the right frequency and cadence..
The link below explains how to do this.
http://ciscoflair.blogspot.co.uk/2009/05/cisco-fxo-disconnect-issue.html
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Yes, i also think there is error value frequency and cadence but I've done like the link that you suggest and the problem still appears
VIP Super Bronze
Post your config.
Hi aokanlawon, please see the attachement
VIP Super Bronze
I dont see your frequency and cadence configuration. Ensure you use the link I sent to you to set the proper values. Thats the only way I know you can resolve it
Hi aokanlawon,
Please see on this part :
dualtone disconnect
  frequency 450
  cadence 363 343
VIP Super Bronze
Why do you have disconnect at the end of the voice class? I dont think it should be there. I also suggest you use multiple frequencies...The key is to get your frequency and cadence as accurate as possible..
dualtone disconnect
  frequency 450
  cadence 363 343
voice class custom-cptone Disconnect,
Disconnect word just word for custom-cptone's name
779
