FXO disconnect problem with PBX Ericsson BP 250
I have connected a PBX ericsson BP 250 to an FXO in my voice enabled router 2811.
The problem is:
When an analog phone attached to the PBX calls an IP phone registred with the CME, the IP phone ring normally. But when the analog phone goes on-hook, the IP phone continues to ring.
Please can you help me.
Thank you very much.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: FXO disconnect problem with PBX Ericsson BP 250
Hi, these should be CPTs for Tunisia:
http://www.3amsystems.com/wireline/tone-search.htm?start=0&kCountry=177&kTone=&frequency=&cadence=
Check if your PBX is actually using one of these.
Hi, are are you using the keyword "opx" in connection plar" ? You need that.
Then if that is not enough you need to configure disconnect supervision, likely based on tones:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml
Thank you very much mr Bevilacqua
I need to khnow this two parameters:
-frequency
-cadence
of the PBX BP-250
Thank you very much
Houichi Nizar
Have tried OPX first ?
For the parameters, set cptone as per you country under voice port. That may be enough.
I don't need a connection plar. So i don't tried opx.
Thank you
So how do you route the call to a specific phone, are you using IVR or what ?
I'm using extension. I call the number of port thet connect the PBX to the FXO. Then i dial the number of IP phone.
Tahnk you
Then yes you need supervisory disconnect. If the default doesn't work, tell us which country are you in, record the tones with a PC and attach the file here.
hello,
thank you first for your assistance.
I'm from tunisia and i use a pbx Ericsson BP 250
in a central office. I would like to khnow the parametres of this command:
voice class custom-cptone Discon
dualtone disconnect
frequency 425
cadence 500 500
thank you very very much
my problme is resolved
Very good, thanks for the appreciation and good luck!
843
