FXO disconnection
marahman78
Is there any way to find which signals are coming from PSTN(Telco)side? I have a FXO disconnection problem and almost tried every thing. Please help.
MAR
18 Replies 18
paolo bevilacqua
Which country are you in?
Check the info from the great guys at:
http://www.3amsystems.com/wireline/tone-search.htm
Yes, i've checked and i make a new custom tone but it didn't resolved my problem. Please advice.
Record your tone on the PC, attach it here together with config and mentioen the applicable country.
Please find the attached tone & config file. Country = Pakistan. Also find the debug file.
MAR
Hi, recording quality is marginal, but try 440 Hz, 275 ms on 275 ms off.
Is voice port configuration is alright ?
Seems so.
I've checked but it didn't work. Please find the attached "debug vpm all" file. I'll be waiting for your useful suggestion.
Tone-based disconnect supervision is not very reliable and sometime doesn't work at all.
However in the debug seems like you're getting battery reversal, try that:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml#topic6
Good luck!
I've tried but no luck. Is there any way to find out which type of signals PSTN are sending.
MAR
It's probably 425 Hz after all. The recording you sent has a lot of noise and the frequency analysis can be impacted. The main problem is that tone-based is unreliable in itself.
Is there any way to find out which type of signals PSTN are sending ?
They are sending the signals detailed above, problems is rotuter doesn't recognize them. Which exact IOS are you using ?
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(3h), RELEASE SOFTWARE (fc2)
c2800nm-adventerprisek9-mz.124-3h.bin
