FXO disconnection
Is there any way to find which signals are coming from PSTN(Telco)side? I have a FXO disconnection problem and almost tried every thing. Please help.
MAR
Hall of Fame Super Gold
Re: FXO disconnection
Which country are you in?
Check the info from the great guys at:
http://www.3amsystems.com/wireline/tone-search.htm
Yes, i've checked and i make a new custom tone but it didn't resolved my problem. Please advice.
Record your tone on the PC, attach it here together with config and mentioen the applicable country.
Please find the attached tone & config file. Country = Pakistan. Also find the debug file.
MAR
Hi, recording quality is marginal, but try 440 Hz, 275 ms on 275 ms off.
Is voice port configuration is alright ?
Seems so.
I've checked but it didn't work. Please find the attached "debug vpm all" file. I'll be waiting for your useful suggestion.
Tone-based disconnect supervision is not very reliable and sometime doesn't work at all.
However in the debug seems like you're getting battery reversal, try that:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800ae2d1.shtml#topic6
Good luck!
I've tried but no luck. Is there any way to find out which type of signals PSTN are sending.
MAR
It's probably 425 Hz after all. The recording you sent has a lot of noise and the frequency analysis can be impacted. The main problem is that tone-based is unreliable in itself.
Is there any way to find out which type of signals PSTN are sending ?
They are sending the signals detailed above, problems is rotuter doesn't recognize them. Which exact IOS are you using ?
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(3h), RELEASE SOFTWARE (fc2)
c2800nm-adventerprisek9-mz.124-3h.bin
That "might" be CSCek27376. Do you use "connection plar XXX" or "connection plar opx XXX", and can you switch to the second if using the first ?
I've checked but no output. So anyway thanks. You did'nt tell me how to check the PSTN signals?
No output for what ? We've checked the PSTN signals already.
What i meant to say is that i've checked but it's not working.
517
