FXO - Incoming calls continuous ringing
Problem - Intermittantly about 3/10 calls experiencing continous ringing.  From GW we can see ring detected using show voice port summary.  ccapi in/out shows the exact same output for failed and working calls.  We don't see the failed calls in Unity Connection Port status.
Call-Flow
PSTN --> FXO H323 GW --> CUCM version7 --> Unity Connection
Wondering if there are any other debugs I could try or if there are any other troubleshooting steps.  Any suggestions would be appreciated.
AK
We are using Loop Start. AK
AK
you need to configure cptone
you need to configure cptone on voice port according to pstn provider
I got same problem I tried
I got same problem I tried change cptone but not working it difference tone. any idea?
Hi, Can you try adding the
Can you try adding the "no battery reversal" command on the voice port. If that also does not fix, then provide detailed symptoms of the issue such as below:
For the pstn user, is the ringback continuous or does it disconnect for him.
Does the incoming call ring and then disconnect. Again ring and disconnect so on.
More details on the issue will  be good.
Deepak
118
